LOL, It's very similar to using peel ply, except that peel ply is left on until the epoxy cures.
Fishbuster, that depends on the definition of strength that you're using. Normally, when talking about composite layups, strength is taken to mean the resistance to tension, torsion and/or shear. In that case, a 60/40 ratio by weight of epoxy to glass is usually optimum. More epoxy is simply weight that contributes no resistance to those forces.
The reason more is less is because, while epoxy is very strong in adhesion and compression, compared to glass it sucks in tension, torsion and shear. So if you have too much epoxy on the inside, the shear resistant layers of glass are separated by a relatively easy to shear layer of epoxy and the layup becomes more liklely to fail in shear. Same for torsion and tension.
Your cockpit is more puncture-resistant because the glass on the inside and out, in combination with the wood, forms a true composite. The wood resists the compressive force of the branch trying to penetrate it, while the inside glass resists the tensile force of the wood trying to bend inwards. The outer layer of glass doesn't actually do all that much in that case except to resist surface abrasion. So yes, more epoxy is good, but only insofar as it's part of a good layup.
As far as endpours go, they're a tremendously inefficient use of epoxy in terms of strength. Wood actually resists compression much better per unit weight than thickened epoxy does. The great virtue of endpours is that they are easy to fabricate and rotproof.
Finally, 3 optimally wet out layers will indeed take a certain amount of glass, regardless of how the layup was done. The issue is whether the layup technique used promotes excess epoxy between the layers. Epoxy usage is more difficult to control for 2 or more at a time, unless something like vacuum bagging is used. Blotting works best when used while putting down 1 layer at a time for a multi-layer layup. Normally you'd only use it on the interior layers if you're finishing bright, but if you're painting you could also blot the outer layer and fill the weave with lightweight fillers like microballoons.
Hope this clarifies things,
