Fiberglassing Wood Duck Transom
I am getting ready to fiberglass the hull on my Wood Duck 12. What is the best way to cut the fiberglass so it ill lay on the transom without wrinkles?
With a pair of sissors?  Sorry I had to do it before someone else did.
i used a small piece of cloth cut on a bias for the nose and transom then cut the full length cloth so that it would overlap one side then the other...this gives me 3-layers of cloth. after 2-3 coats of epoxy to fill the weave you can sand the overlap and blend them in....it works. use a plastic squeegee and run the wrinkles out. once the cloth gets saturated with epoxy it become more forgiving.
good luck
