I've finally glassed, epoxied, epoxied and epoxied the WD and am doing the final sand before I paint + varnish.
In some spots to get it smooth I have sanded down to the glass, and in a several other spots there are still some 'pits' where the dips down. Most the size of a peppercorn, maybe 1-2 mm deep.
Two questions:
1) Do I need to do another thin epoxy coat over where I sanded to the glass? I am planning on bottom-paint + color paint + varnish, so think I will be ok. However it is better to check and fix it now, instead of sanidng it back down later on.
2) for the small pits should I float epoxy into filling the, or just leave them and assume they will be filled with the paint + varnish. I'm not sure if the final finish will reflect any of the pits, which is what I am most worried about.
Thx.
My slow progress is here: http://logicalphilosopher.blogspot.com/search/label/kayak
