Only have accessorizing left! The finish could definitely be better but seems pretty awesome to me from a few feet away. A little tricky working in an open carport, even with a tarp tent around it.
https://goo.gl/photos/FbixdVhGkmnYvP1FA
Going to try using 1/4" cork for the pads, with bungie web, and brass tow loop.
Was thinking about putting in an inspection plate, has anyone located them in the back? I like the look much better back there.
Are you placing the inspection hole(deck port) for a ditty bag to place items to keep dry or actual inspection? If you want to keep the plain look of the wood I'd recommend ditching a port and just go with a breather valve that's made with brass screw(to go with your brass tow hook) and bungie rigging. Unless you plan on sticking a pipe camera to see the insides coz with a 6" deck port vision is limited inside.
I was goign to put it in for a dry bag, but at this point I will probably skip it. Our first kid is due in march so long trips are probably out of the question for quite a while. :)
And I'd want to paint the deck port brass or something to match which is probably a pain to do in a way that doesn't flake off. So just have the bungies left and I'm done. Just in time for the rain!
I used the 'stock' pads as a template to cut out cork pads. Sanded the edges. Used 3m 90 spray adhesive to stick them to the board, and put a bead of silicon around the edges to try to keep them from crumbling. See how it holds up, but looks pretty good. Wish someone just made them with a strong edge and a peel and stick back though. :)
