I've got an Annapolis wherry that i boght from someone else, and I'd like to install oarlocks for fixed seat rowing. I was thinking of mounting them on short outriggers, sort of like those on Dave Gentry's Ruth, and maybe raising them up a little bit. Does anyone know where exactly the oarlocks should be on this boat? Has anyone installed outriggers?
I thought I could set up my Annapolis Wherry Tandem with fixed seat and short 6" outriggers made of 3/8" flat aluminum stock. I set the seat up about where the center of the boat was and maybe a foot aft. Foot braces were a bit of a problem since the most comfortable position was with my legs over the last frame, and digging into the back of my calves. Had to reposition the seat as a result.
It really didn't matter. Even 3/8" flat aluminum bolted to the rail, and reinforced with back plates was no match for the torque of the oars...or maybe it was just me being too strong a rower. (Blackburn Challenge winner in home built wherry 1999 & 2000)
Either way, within 5 or 6 strokes, the aluminum bent and twisted so that no rowing could be done. Thank goodness I brought a paddle 'just in case'.
Think stainless if you do a fixed system. And try to keep your butt in the center of the boat. Too far forward (as was my position after I installed the Row Wing) caused bobbing, which slowed me down considerably.
Hope that helps.
john Zeigler
