I am considering building another CLC boat this winter. However, this time I will be workiing in a basement, not a garage. I have a nice sraight shot to the outside, but I need to build a boat that, turned on its side, is no wider than the exterior door.
Can any of you builders / owners out there tell give me the dimensions from the bottom to the highest spot on the gunwale for the boats I am considering 1) Lighthouse Tender, 2) Chester yawl, 3) Jimmy Skiff, and 4) Mill Creek 13?
THANKS, Ray
One of the most helpful things that CLC does is provide the minimum clearance space to get a boat in and out of a shop. It's typically at the bottom of the sales page for each boat labeled "Window Size Requirements". So from the bottom of the pages for the boats you requested, here they are:
Lighthouse Tender Peapod
Chester Yawl
Jimmy Skiff II
Mill Creek 13
Lazlo,
The info is much appreciated. I gave myself a dope slap for not noticing that info at the bottom of the boat page, after years of looking at CLC boats.
Thanks,
Ray
