Hatch Cover
Good Afternoon,
I am working on the hatch of my WD 12. I am wondering how one removes it? I did not see any instructions for a handle or "finger hole"to lift it off.
Thanks for the help
Brian
Brian,
If you use the standard retainers that come with the kit, you don't need anything. Once you rotate the wooden clips the foam will pop the hatch up and you can just lift it off. If you use internal hold-downs, you'll need a loop, a finger hole, a knob, etc. Use whichever you prefer, it's your chance to get creative.
I used home-made internal hold-downs and a finger hole for my WD12. (Click on the image below for a larger picture) The hold-downs are described here and here.
Have fun,
