Drape the glass cloth over your hull. If the hull isn't smooth, the cloth will catch on rough areas/burrs and distort the weave. So be sure you can run your bare hands over the entire area you are going to glass, without snagging them on anything (be reasonable, don't rip your hands, it's a test of smoothness after you've sanded), then drape the cloth.
Carefully adjust the glass so you have 7 to 10 cm hanging over one edge of the hull at its widest point. A large, clean brush really helps here. And take your time. Be neat. If you jerk on the glass you will probably distort the weave (this means more work for you later). Then use the brush (hands are used by many, but for your first couple of glass jobs, a brush is far better) to smooth out the glass, starting at the middle and working out radially, even over the sides. It will take a bit more patience and TLC at the bow but the glass will slowly conform to the shape. THE STERN WILL NOT!
The excess glass hanging off the sides and bow can be trimmed so 7-10 cm is left loose. If, when you apply the epoxy, you don't let it drip off the edges and then try to save it, you won't have to deal with too many threads. You want to spread the epoxy around so you only have a cm or so of the overhanging glass wet. That insures you have covered the hull and makes the glass overhang easier to trim with a sharp blade when the epoxy has turned green (i.e., stiff but not rock hard).
At the stern you'll have to overlap the glass and later add a small patch. Not a big deal, but can be messy. Leave it for last, make sure you've left plenty of time, and don't use epoxy that is ready to gell in the cup. Relax. Then take a SHARP blade and slice the glass along the keel where it is not conforming to the sharp bend of the stern. Once that cut is started you can finish with sharp scissors (when my scissors are sharp I use them here so I don't distort the cloth and make a lot of loose threads), but cut along the extension of the keel line while trying not to lift too much of the glass you've smoothed out already. I usually leave the last 5-8 cm along the sides free of epoxy until after this cut. Trim the glass so each flap will overlap the other side by 5-cm. Then bend back one flap toward the bow and wrap the other flap around the stern and epoxy it to the hull. Some of the glass at the curve of the keel to the stern is not going to stay down on the hull; it will stick up like a picket fence. Carefully trim off the offending threads. Now wrap the last flap around the stern, over the first flap, and epoxy. You'll have the picket fence effect again at the curve. Don't worry about
Carefull go back over the hull using a smooth squeegie and remove excess epoxy (glossy and puddling are bad) and making sure all of the glass is wet (white is bad) and you have no pinholes. An hour or so later go over the hull (and floor) again looking for drips and runs.
When the epoxy is green (6 hours or so at 30C), trim the overhang around the hull and the picket fence or threads at the stern. Smooth the glass at the stern, fairing it some to the hull but not cutting into the hull. Then apply the bias-cut glass patch. (Bias cut means the threads are at 45-degrees to the edges of the patch.) The patch will conform easily to the curve, you just need to be carefull applying the epoxy, don't drag the patch around too much.
Be aware of potential for out gassing by the plywood. This can occur if the temperature increases before the epoxy seals the air in the wood. You'll want to work when the temperature is max or cooling. And don't put the hull in the sun to speed the cure; that will really heat the wood and let the air escape out under the fiberglass.
Apologize for the length of this. Good luck.
