First time boat builder here, working on a shearwater sport. I'm having a heck of a time stitching the side panels to the bottom panels. I stitched everything up generally following the instructions after using the bulkhead top open the bottom panels like a book. The bow and stern areas came together snuggly, as did the areas between the two permanent bulkheads. However, on the sections between the permanent and temporary bulkheads on both the bow and stern ends, the side panels hung over the top of the bottom panels. After tightening and tightening, drilling more holes and fighting, I gave up and took it all apart.
I started over, intensely following the instructions (tight stitches bow and stern, loose stitches everywhere else, securing bulkheads on the bottom, then the top of the bulkheads to the side panels, then the rest of the side panels loosely), with the same results.
I had a beer and a rest overnight, I read through the forums. It seemed like the typical recommendation here is to do up the panels loosely and work from bow to stern. So I gave this a try. Sadly, same results again. The area between the permanent bulkheads, and the fit on the permanent bulkheads themselves is good. While the fit on the bow and stern themselves is a looser fit than before, they still look like they will line up if tightened. However, the section between permanent bulkheads and temporary bulkheads is still a problem. The side panels hang over the outside of the bottom panels. The panels do not have the best fit to the temporary bulkheads either, while keeping stitching loose.
I *believe* I have the bottom panel bow lined up with the side panel bow (the pre-drilled holes line up, longer length past puzzle joint on bottom panels toward bow, side panels with slightly taller rise toward bow).
I only have pictures from this third try, where everything is still loose. Attaching one in case the description of side panels hanging over bottom panels does not make sense. For what it is worth, they can be muscled and held into place, which is why the first go round I went about tightening the heck out of them. But it is a bit like nailing jello to the wall, have to use plier to tighten flush to the wood, this will then cause something else to slip out of alignment.
Suggestions??
