I have been unable to get the Petrel Play SG hatch recess assembled, so I'm pretty well stuck in my build.
I can't get the puzzle joint on either hatch to close all the way and have ~1/4 inch gap. I've disassembled and started over several times at this point, and can't figure this out. Does anyone have any advice?
   I have had the same problem, especially with the bow hatch. In fact I ordered a second front hatch. I had to heat the wood with a small ceramic electric heater to soften the wood. This worked well for me. I was told you can use a hair dryer or the microwave oven.
I would try heating the wood to make it more flexible. Good luck.
I built this boat for my wife in 2018 and had the same issue. Mine actually broke as I stitched it together. I had to patch it with 4-once fiberglass cloth and epoxy. I remember tightening things gradually all the way around to force it into place after the repair.
