hi folks, I am about to glass the hull of my WD12... and I'm wondering about people's experience with getting all the wrinkles out... I know that glass cloth has fair amount of give and can be worked flat. I will be using MAS low viscostiy with slow hardener.
Also, Lazslo, looking ahead to the deck, I am planning on using your trick for the over lap with the packing tape. Question: how flat were you able to get the over lapped glass? Did you need to cut any darts?
Signed: Dave "stressed but happy builder" Donaldson
David
Just finished the glass on the top and bottom of my Wd12, and have a wd10 i finished over the winter.
For the hull i was able to smooth out the glass completely by hand before adding the epoxy. And starting in the middle and working out to the ends with a squegee i had no wrinkles form.
For the Deck, smoothed out by hand first. I had a few wrinkles showed up on the overlap as I was going around the curve of the deck. Not a one did not just lay flat when smoothed over by the squeegee.
Only cutting i did was at the bow and stern.
Lazslo's approach has worked well twice for me. i used Blue painters tape with no issues.
Have fun, and happy paddling.
David
I used the idea of taping too. It's a great idea, but don't make the mistake I did of leaving the tape on too long. It was very difficult to remove. However, once I was able to, you could barely see the end of the tape.
Rich
What Dave & Rich said. My variation was that I used my (gloved) hand to spread the epoxy. It works better on the first coat for me than squeegees, rollers or brushes. I can feel if an area has too much or not enough epoxy.
Thanks guys, did the deed last night, came out awesome! I am staining the centre panel today and glassing the deck tomorrow. In the water by June!
