A few weeks ago, I took my JS out for a solo sail in a pretty healthy breeze of around 12-15 mph. I was tacking back and forth for about 20 minutes without any problems. On what ended up being my final tack, the sail filled with wind right after I came about, before I even had a chance to control it with the sheet. So I was dumped into the water in about 3-4 seconds.
Luckily, I was in sheltered waters, in a fairly busy area close to the boat ramp. I first tried swimming the boat into shallow water near the shore (roughly 50 ft away), but it would not move. It turned out the top of the mast had become buried in the mud. Some local fishermen came to my aid and helped me get the boat upright. Boat was largely undamaged but not so much my pride.
I completed this boat about 6 months ago after taking an April class at CLC. So I’m still learning how to sail it. I suspect the cause of the capsize was that the sheet got tangled in the mounting bracket for the motor this was located on the transom. I had the compact, lightweight all-electric “eLite” motor made by ePropulsion on this boat. It’s 1.5 hp and works great for my needs, which is to just help with going to/from the trailer and to/from the dock.
Which brings me to the main reason for this post. I built this boat mainly to sail, but the motor is essential for docking/trailering. The center of the transom is where the motor is meant to go on these boats, but that is also where the rudder needs to go. So it seems to me that we have an inherently challenging situation right from the start.
I tried addressing this by mounting the motor off to one side of the transom (where it sits somewhat higher than the middle of the transom), but it can be tricky to control the throttle on the motor while also trying steer with both the motor and rudder at the same time. Also with this arrangement, the rudder still hits the prop on a sharp turn because there’s not enough space between them. And finally, lines can get tangled in this motor mounting bracket sitting relatively high on the transom, as I learned the hard way.
I’m thinking of installing an actual outboard motor bracket Amazon.com: Marinebaby Boat Outboard Motor Bracket, Aluminum Boat Engine Support 20 HP : Sports & Outdoors.
My reasoning is that I want to get the motor and bracket completely clear of the transom and away from the rudder. I’m waiting for the bracket to arrive. I know it will add unwanted weight to the stern as well as detract from the aesthetics of the boat but I don’t know what else to do.
Any insights or advice about this issue of positioning a small outboard motor on a JS II are most appreciated.
