Getting ready to build the MC 16.5. I read in /Kayaks You Can Build/ about adding a keel to a MC 13. Just wondering if anyone has done this and if they would recommend doing it? I am considering adding it to my kayak because it flat-bottomed with no v-shaped hull like the other CLC designs. Dave
Don't do it. The Mill Creek's stern is deeply immersed and functions perfectly as a skeg for directional stability. Ted Moores told me he regretted adding a keel to his Mill Creek 13, and of the thousand or so Mill Creek 16.5's out there I've not once heard that someone wanted a keel.
My Mill Creek 13 tracks fantastic. I only imagine the 16.5 is even better. Can’t imagine needing any assistance from a keel.
I have built both the 13 and 16.5 and they don’t need a keel , it would only cause the boat to bottom earlier in shallow waters.
I have the 16.5 and it does get pushed around alot in the wind. It tracks well in calm water, but it was essential to add a rudder for windy conditions. I think you would be better off adding a rudder than a keel if you find it to be difficult to control. My advice… finish it first & add on later if you need to. A keel should be easy to retrofit.
If you are considering adding a keel to improve directional stability, please read my comments under "Which Rudder for Sailing a Triple" here on teh forum. The comments about lift to drag and aspect ratio all apply to this. A keel will certainly add drag and yet will give you precious little improvement in directional stability. If this is your issue, install a high aspect ratio skeg or rudder.
Paul G
If your primary concern is weathercocking in a beam sea or with a wind on your beam, you might want to consider adding a retractable skeg. CLC offers both a kit and plans, and they're pretty easy to install, even after the boat is finished if you have a rear hatch. I have them in my Ches. 14 and LT-17, although I'm not planning to install one in the Mill Creek 15 I'm building. The nice thing about a retractable skeg is that it adds negligible drag when retracted, and not that much even when deployed. Also, when retracted it doesn't add anything to your draft.
-- Jim C
