A while back I built a MC from plans that I has purchased back in 2010.
This spring I built the sail rig, using a bermudan sail from a well known canoe sail company in the UK. It is great fun, stable and reasonably quick. It is however a bit of a hassle getting the whole thing on and off the beach where I usually sail in the Solway, and there are days when I would like to be able to sail without the outriggers. The sail/ mast combo I have is not really suitable for that, at least with my abilities. I hope therefore to buy the standing lug sail from CLCs UK agents, and build the mast and spars. The plans and instruction manual give sail dimensions, but bo indication of mast height, or construction. Not sure whether to build a solid wooden mast or use aluminium, and what dimensions would be appropriate. I would appreciate any advice from anyone who has made their own mast/spars for this boat.
I have been reading about outriggers for the MC that allows for a 70 sail. It is mentioned that some beefing up of the mast is necessary to keep the boat from breaking up. I cannot find much information on it, but I am digging.
Morning
The mast from CLC is about 18- 20ft and aluminum. (It needs to be polyurethaned to keep the aluminum oxide down.). Wood would be perhaps heavier. If you can find a carbon mast from a one design sailboat, that might be ideal. I have the 55 sq ft sail. I think that with the weight and wind age that it will be very unstable with the sail that I am using
