Hi.While trailering my boat, the tie down strap came loose and got under the trailer wheel. The resulting downward pull broke the panel and trim (see pics). I’m concerned about the location because it’s at the oarlock so repairs might have a structural weakness. My plan is to stitch and glue in a piece of panel, and then cut out and replace the trim pieces. Questions: 1) Should I try to puzzle cut the panel repair? 2) Should I fiberglass over the panel repair? 3) How do I get the proper bends in the shorter repair pieces 4)How deep should I sand to prepare the repair area? Thanks for your thoughts. Jack
I once had a canoe I’d just taken from the water and set up on the factory rack built on a truck bed aluminum topper, then went to move away from a ramp to tie on, but had the rope dangling as it was tied to the rack. The rope went under a tire while I was moving and bent the rack pretty good, but all was fixable. The lessons we learn the hard way.
As to the NE Dory - been there, done that - almost the same damage, but mine was considerably worse. Lightning-struck tree limb about 8 inches in diameter fell on my dory while sitting (covered) on the trailer in the back yard. (The 30 inch diameter gum tree EXPLODED pretty good from that lightning strike!) Anyway here is what I did, and what you might do. Pictures will follow.
I highly recommend first putting in a new gunwale piece. That will give you something to “build to” when installing the lapstrake repair. Find a nice piece (board) of walnut, cherry or mahogany, or whatever wood you decide to use that might match well. The board needs to be at least as thick as the gunwale, and then planed (if necessary) to match the gunwale thickness. Cut off the existing guwale at each end of your repair at least several inches LONGER than any damage on the top strake panel, and of course long enough to remove all damaged gunwale (leaving at east several inches of “good” top laptrake in place at each end of the gunwal replacement zone. Youll be using the good lapstrake to clamp to when you put your new gunwale in place - it will be a curved piece of wood bridging the gap in your repair area during the repair process. Make 45 degree (or greater, but 45 deg is probably enough, and the higher the lap angle you choose the harder it will be to get just right) cuts when you cut off the existing gunwale, wide part of the angle facing out on each end - you’ll be scarfing your new gunwale to the old at each end. Then make a template that the gunwale repair piece match the curvature of the old gunwale, with ends cut to length on an angle to match you lap joints on the old existing gunwale. Your board will need to be wide enough to fit your curved template. When you cut out the new gunwale you’ll have some slight cross-grain effect going on that wasn’t present in the bent gunwale, but the curve isn’t so large that I found any problem. This prevents trying to re-make a bent-wood gunwale (and getting the curvature right while doing so). Of course you could make up a jig and make a bent-wood gunwal repair piece, but I was to lazy to do that, and I dont think the end repair strenth or appearance suffered at all.
Before glueing the the new gunwale in place decide how much of the top lapstrake damage you are going to remove, and and then remove the wood and prep the scarfs (and puzzle joint, if needed) on the boat. I had to move a couple of full strakes (in depth, not full length). For you I’d go down to the first strake seam. I put a scarf joint on one end, and puzzle joint on the other end. I cleaned the old puzzle carefully with a dremel, and re-created the new one likewise with a careful final fitting with a dremel. It looks like you could scarf both ends for your repair if desired. Also, make the same partial-thickness edge on the strake-bottom mating surface so that you repair piece will mate with the existaing strake below. Basically you are making a short piece of okume ply that will look like a small section of the original lapstrake panel.
Do as much fit-checking as possible on all parts, then get out the epoxy. First, epoxy the gunwale replacement and clamp in place, let harden up. Then epoxy your new lapstrake repair in place. Stitches on the ends and bottom sides might help, but I didn’t need to do that. I used various clamps and sticks to press the correct bend into the panel, and of course clamping the top edge to the new gunwale was a great help.
FYI, on initial construction I put doubler blocks about 4 inches long, 1 inch square (cut off scrap ends of the gunwales) that I shaped to fit up under the gunwales at the oar lock locations. I think this added better bite for screws and much strength in that high stress area, and they are virtually invisible under the gunwale anyway.
For my repair I elected to glass over the entire repair area on the outside of the (painted) hull, just because. It is virtually invisible. Do so if you desire, otherwise just epoxy coat, paint and varnish to finish the repair. I had to try to match stain on my boat, which was tough, and actually did OK - the color difference shows in the photos more visibly than it does to the naked eye. Good luck, ask if you have question.
I took another good long look at your picture of damage. Hard to tell from the picture, but the fracture of the gunwale looks long, and it looks like it is right along the glue-line between the gunwale and top strake for some length, and that the area where it is fractured in the wood grain itself might be able to be made to mate up. Maybe you can remove and prep the lapstrake repair area, then just reposition and epoxy the existing gunwale back into place, then install the lapstrake patch? Basically same process as I described above, but using the existing gunwale to repair in place.
Thanks, Jeff. I’d seen your post on your repair, and comend you on it and your thorough description. I’ll use your suggestions and get to work!
great job Jeff, impressive, again very nice work
