night heron end forms
The kit end forms for the greenland night heron don't show a bevel line.  Are they already cut to accomodate an internal stem?  Meaning can I laminate the stem directly over the form as is or do I need to cut?
I can't directly answer your question, but the bevel lines where well marked (CNC scribe lines) on both sets of forms that I bought from CLC (Mystery and Yukon).  You should be able to tell by comparing the forms with the plans.  If not, I'd call CLC and ask.  In any event, the exact length of the boat +/- an couple issues won't really matter unless you are planning to race it.
I am not sure what you are planning, but carving a solid internal stem is really easy.  I suggest watching Nisk Schade's video demonstrating that on a Bootlegger Sport.
First picture shows Mystery forms as delivered except that I highlighted the bevel lines with a red magic marker.  Second shows completed solid internal stem.
Hi JP,
i have built the night heron and its a bit confusing....but the form needs to be cut back to accomodate an internal/beveled stem.
if i recall, they may have included a piece in the kit that represents the beveled stem.  you need to place that piece over the stem and trace the bevel line and then cut that off.  then add back a proper piece of spuce or other wood.that can serve as an internal stem.   the greenboard/particle that they now ship for forms/stems is not suitable material to actually include in the boats construction.
i am looking to see if i have a good picture of that from my construction to share with you.
howard
looks like mark gave a good illustration.  my sense is depending on the vintage of the kit, they may have scribed it for you (newer kits/designs)  in the older kits/designs, you had to scribe it yourself.
but
   Thanks for quick replies.  Makes sense now.  I will have to cut the end form to attach an internal stem.  Easy enough and I have bendable wood to laminate for a stem.  Also it turns out the bottom point of the 1,2,16 and 17 forms, where they attach to the end forms mark where I need to cut.
Thanks and stay safe,
Jeff
   Howard, on further inspection of the rest of the kit box, I found the pieces of particle board based, internal stem templates you're talking about.
Since you have templates, it will be much easier and quicker to carve the inner stems then laminating them.  Watch this video by Nick: https://youtu.be/hAh-qPYf0rk
situs sbobetmu.co Merupakan Agen Judi Online Terpercaya ,
Agen piala eropa
Agen Sbobet, sbobet Casino ,
SbobetOnline dan Slots Online .
Sebagai situs judi online terpercaya dan berpengalaman, kami bertekad untuk memberikan kepuasaan kepada
seluruh member kami dari sisi pelayanan maupun penyediaan permainan yang ada di situs kami. Sebagai upaya
kami untuk memberikan kemudahan bagi para member untuk bermain semua permainan,
seperti Judi Bola, Casino, Poker, Ceme, Capsa, QQ, Poker,
Slots dan Live Gaming maka kami menyajikan semua permainan tersebut hanya dengan 1 User ID.
REKANPOKER SitusPoker Online Terpercaya Uang Asli REKANPOKER adalah situs
Pokeronline yang memiliki kualitas terbaik situs Poker Online
dengan banyak bonus
situs judi slot terpercaya di indonesia,
agen judi slot online dengan deposit mrah,
permainan judi slot
dengan bermacam pilihan gmes slot jangan ragu seger bergabung
dengan situs judi slot online
Daftar slot online
judi slot terbaik dan terpercaya dan terman dan ada juga ermainan judi lainnya seperti
Togel Singapura Togel Hongkong Togel Online HongkongPools
IONTOGEL IONTOGEL Bandar Togel Online SingaporePools Dan HongkongPools Sehingga Lebih Mudah Dalam Bermain
Togel Online dan agen
slotyang terpernting adalah ion togel pasti membayar
Situs agen generasipoker judi bandar poker dominoqqpoker online
dominoqq
Situs agen judi generasipoker judi bandar poker dominoqq
pokerSitus agen generasipoker judi bandar poker dominoqq
poker
Agen Judi Online, Poker Online, Domino QQ, Bandar Ceme Online Terbaik di Indonesia
qqmaxwin sebagai agen situs judi casino Online, judi Online,
Agen Judi Online,
Agen Judi Online, Poker Online, Domino QQ, Bandar Ceme Online Terbaik di Indonesia Terbaik di Indonesia
KakiQQsebagai agen situs judi Poker Online,
DominoQQ, BandarQ judi online,
DominoQQ, bandarq online
terbaik, terpopuler, terbesar, terpercaya serta teraman yang ada di Indonesia
dengan ketersediaan pada jenis promosi bonus refferal sebesar 20% setiap minggu dan juga adanya bonus cashback mencapai sebesar 0,5% setiap minggunya
qqCobaQQ99 adalah situs judi online yang sudah terkenal pada awal tahun 2015.
Dan berbagai jenis dari permainan judi online uang asli yang disediakan diantaranya
adalah Poker Online,
DominoQQ, Adu Q, BandarQ Online,
Capsa Susun, Bandar Poker,
DominoQQ Online
Situs Poker Online
Uang Asli Terbaik dan Terpercaya di Indonesia, Situs Bandar Agen Judi
Poker Situs Poker Online Terpopuler Online Indonesia, Daftar Poker Online
di Agen Poker Terbaik Situs Poker Online Populer
