I will be installing a sliding seat rowing frame on my Noreaster kDory that is under construction. What is the recommended method of mounting / attaching the rowing frame. I ordered it from CLC and it is supposed to be for the Noreaster but I do not see, or find, and mounting instructions or fittings.
Any update on this? I'm building a NED too, and am thinking about adding a sliding seat.
No, I have not received any information and I am at almost ready to install the rowing frame. Have you installed, and if so, can you share how you did it?
Sorry. I've got no info for you. I'm still trying to finish my NED build and launch her before I add on the sliding seat.
Have you called CLC? Just getting someone on the phone has helped me a few times already.
