This is my first build. Would it be a problem to remove the stiching while the hull is upside down after the initial epoxing has cured? It seems easier to back fill the holes while the boat is in this position before starting the inside?
Thanks Brian
I should think that would be fine. If the build order is like the skerry, the frames are all in, so it should be fairly rigid. Just don't drop it! You know the trick of using a soldering iron to heat the copper wire to pull through the hole after snipping?
Hi Sawdust. Thanks for the reply and soldering iron tip.
Brian
