oar length
Hi...ordering the EastportNesting Pram kit. Just wondering if the 6ft.6inch length on those is adequate or should I go for the 7ft. length? Guess they thought the 6ft.6 was a good compromise to row from both stations.I'm 6ft,185lbs. was also considering the straight blade. Any input from current Eastport owners would be appeciated. Thanks, Mike K.
Personally I would err on the larger oar. Unless you own a board stretcher..;)
