I have a 2hp Honda short shaft outboard and wondering if I can attach a bracket to the transom to use it as an outboard, steering with the tiller
Does it already have the doubler shown in the picture below? If so, you shoulde be good to go.
Is that a 2-stroke or 4-stroke Honda? If it's a 4-stroke, you may also need a tiller extension so that you can sit far enough forward to balance it. You don't want to drag your transom or the boat will slow way down.
Have fun,
Thanks for the pic. I assume that the doubler is epoxied on and that the 4 fasteners are wood screws. I am still in the epoxy stage and though the kit doesn't have a doubler I can make one. I will likely need to convert the 4 stroke 2hp honda to a long shaft.
