Folks, update on Oxford II roqinf shell build, ready for glassing. I bought the kit version, it was well made and packaged. Shown is a WIntec rig bought separately. Need to purchase the slider rails and attachemnts last. I did need to ge a little extra epoxy from the kitted version, or atl least i think i need it. Im not sure ther'e senogh to finish the hull glassing so I ordered an addtional 1/2 gallon resin and quart of hardener
https://photos.app.goo.gl/tfKp3udP4sRQ25556
I'll post some lessons learned as well, Some slight improvements to applying wet fiberglass seams and filleting goop.
Looks great! After reading your post I looked at the CLC kit and noticed they've changed the rig they offer with this boat, going with a welded tubular setup instead of the airfoil. Was the previous CLC rig also a Wintec? Curious if you have any insights on the change. I definitely prefer the look of your rig over the new version.
And I look forward to hearing about your "lessons learned." One of these days I may build this shell myself.
JackJ, yes they changed the rig to a tubular assembl, i also preferred the airfoil rig which i believe was a Wintec rig. The rig is available by going to Wintec directly and CLC advises the saem if you want that one. They sell the rig and a variety of oarlocks and pin assemblies for different diameters.
Oarmaster also makes a tubular rig and sliding seat assembly but not sure how available they are. These are also heavier.
I'll post the lesso s learned shortly.
I think the selection of rowing rig. I would like to know the reason for the switch. Beautiful work.
Did you have to custom order the Wintech rigging, or was the Quick Release Foil Wing Rigger (Sculling) as listed on their site compatable? I see an option that looks standard for the foil rigging, and an option to order one with custom dimentions.
