On another thread, a very interesting technique popped up for cutting the boat in half if you're making the Take-Apart PM or the Nesting EP. The conversation started with discussing the possibility of making some rigging videos and another poster requested a video of cutting the boat in half. In the interest of posterity, here's the discussion:
"As far as cutting apart the ENP, I found drilling a series of 1/8" holes through the cardboard using a long bit (as the manual suggests for the faint-hearted among us) worked very well. The resulting line of holes makes for an easy guide for sawing, and helps manage one's anxiety."
"The Passagemaker manual does not include that trick. Do you do it before installing the seat? Is there a way to center the drill tip in the cardboard gap?"
"I'm building an ENP which is sawn in half during the construction, the "gap" having been previously occupied by a sacrificial sheet of cardboard at the junction between forward and aft halves. I am completely unfamiliar with the Passagemaker build, but if it's also to be sawn in half and a cardboard spacer is involved at the joint, I imagine the process is similar. (However, I don't know what the appropriate sequencing would be with respect to "installing the seat.")
"In my case, with the ENP hull right-side up and on saw horses, I used a 1/8" drill bit ("Irwin" brand, 12" long, sold in local hardware stores) to drill a series of holes down through the cardboard and out through the hull. The weight of the hand-held drill was sufficient to push the spinning bit down through the channels in the cardboard. I kept the bit vertical (more to avoid bending the bit than drilling through a bulkhead), but I knew that as long as the bit met no resistance until it had penetrated to the hull bottom, I was still within the sacrificial cardboard layer. I drilled enough holes so that when the hull was turned over for sawing, the line to be sawn was obvious. Actually making the cut was still anxiety-provoking, but the holes assured that I cut in the correct plane."
I know CLC probably has zero interest in revisiting any of these manuals, but I would think it would be easy to insert some sort of addendum into the manuals describing the above technique as they're shipped.
I can honestly say that fear of cutting my PMD in half was a very large factor in not making the take-apart version. Also the fact that the additional bulkhead meant buying another sheet of okoume, which I wasn't in a position to do at the time.
Anyway, the purpose of this "re-post" is to facilitate future builders being able to search for this kind of info on the forum here, especially since PMDBuilders.net is defunct.
