I’m wiring in the bulkheads prior to tabbing the exterior seams. Is it unusual for the bulkheads to extend past the sheer line by approximately 3/16 in? The bulkheads s appear nice and tight to hull interior and I don’t see anymore slack to take out to sink them lower in hull. Only way I can see is to loosen hull seams to open them up which doesn’t seem like the right way to go forward.
Looking back at some photos, ours did stick up a bit. We rounded them off flush once everything was glued up tight.
Yes, not to worry. If the "shark fins" stick up a bit, you can easily shape them to fit your gunwale (another great use for the Shinto rasp). Or, you can do like I did and make the rub rails cover the exposed plywood edge of the shear plank, which will make them flush with the top of your "shark fins". BTW, I also doubled up all my "shark fins" to give it a beefier appearance and for more meat for the padeyes I used for the shrouds.
