I have just laminated the spray rails on my Peeler Skiff and have two issues. I used #8 3" wood screws with phillips heads into predrilled pilot holes and a fully charged DeWalt drill but could not get the last foot or so (forward) to lay flat against the hull. In that segment I put screws in at 6" intervals to try and get it down but to no avail. The second issue is that I managed to strip several of the screw heads in trying to get the strips down to the hull. So now I have spray rails that do not conform to the hull for the last foot and I can't get them off to shape them. I could get new strips and try steaming them or I could shorten the rail by cutting off the segment that does not conform. Any other ideas? Also a more pressing issue is how to get the damaged screws out?
Thanks again everyone for your suggestions.
Kendall Jones
It's the path of least resistance, but one solution would be simply to fill the gap between hull and spray rail with thickened epoxy. No loss in strength or function that way. The screws become entombed, but since they're surrounded by epoxy, they aren't going to rust and harm your finish.
Thanks to both of you. The problem with the filling the gap with thickened epoxy solution is that there is polyethelene plastic under the spray rails now so they are only attached by the remaining screws. Maybe the solution is to pry them out, repair the hull damage with thickened expoxy, shape the rails and then reattach, filling the gap as you have suggested. I could even make the forward rail section have a lower profile to compensate for the extra height created by the gap. Thoughts?
Kendall
Kendall,
I'm not clear from your post if you've already epoxied the rails. I'm assuming that you have not. If you have, I don't have any helpful suggestions. When we built my Peeler Skiff, About Time, we installed the spray rails in steps:
- Drilled holes (slightly larger than the screws) for drywall screws in the inner strip and attached it to the hull to confirm that the screws could pull the wood tightly to the hull.
- We backed out the screws and thoroughly waxed them so that they wouldn't get epocied in place.
- We applied thickened epoxy to the wood strip and acrewed it back to the hull.
- After the epoxy had thoroughly set (waited a day) we removed the screws.
- Drilled holes (slightly larger than the screws) for drywall screws in the outer strip and attached it to the inner strip to confirm that the screws could pull the wood tightly to the inner strip.
- We applied thickened epoxy to the outer strip and acrewed it back to the inner strip.
- Used a rasp and sander to shape and smooth the spray rail.
The drywall screws were long enough to penetrate the thickness of the hull, but only one one each side was outside the bouyancy chambers. As I was going to paint the inside anyway, it didnt worry me.
The problem with pre-drilling the screw holes through both layers of wood, is that the bend pulls the holes out of alignment, effectively locking the screws in place. But I'm sure you now know this. Fortunately, my grandfather warned me about it 60+ years ago.
As to the damaged screws, I'd Google "tool to remove stripped screws". This is apparently not an uncommon problem :).
Wishing you the best of luck,
Dick
Kendall,
I guess my login had expired while I was writing the response.
Anyway, here are pictures of my Peeler, About Time.
Let us know what you end up doing.
Regards,
Dick
I noticed you trailer youre skiff with a mini. Do you think i could manage with a civic? I recently purchased a carolina dory about the same size with a 25hp evinrude.
Maybe too late now but starting from the bow end to stern would have helped. I had an assistant help with the alignment and he could easily lever the rails against the first screws at the bow end. You might consider trying to get a hack saw blade between the rails and hull to release the rails, patch the holes and start over from the bow end with help. The finished rails spring back some but go on easy and fit tight start from bow end. I had a 1/16 inch gap at the forward end the rest was tight to hull.
