PMD lug rig mast fit
In dry fitting the mast thru the forward seat cutout, mast partner and into the mast step, I find there is a fair amount of play for the mast. Is this normal? My cutout is not quite precise - it could be squared up a bit ( I’m not sure how yet but..) but the mast partner and step are both preformed and allow the play. Should I be concerned? Thanks.
Bruce
Bruce, some slop at the partner is pretty normal on these lug rigs, the step is what actually carries the load and keeps things aligned. Once the halyard and any downhaul are tensioned it’ll snug up more than you’d think dry fitting on the bench. I’d hold off tightening up that cutout until after your first sail, a little play there also gives you room to fine tune rake for balance. If it’s still bothering you after that, a couple wraps of leather or friction tape on the mast at the partner is an easy fix that’s fully reversible.
Thanks much - very helpful.
Bruce M Greenwald
AEP Capital LLC
366 Madison Avenue 8th Fl
New York NY 10017
212-641-5185 (office)
917-545-9700 (mobile)
212-641-5009(fax)
I got a pack of softwood wedges at the Lowe’s and trimmed them for the faces of the mast at the upper and lower mast step holes. That let me adjust the alignment side to side and fore and aft rake. I marked each wedge with location and line to match the hole edge then varnished them. Turned out I didn’t need all 8 just 2 for fore and aft, one forward on the upper hole and one aft for lower.
That way the mast is aligned and doesn’t flop around. I also tacked some split leather flaps in the hole with copper brads for chafe protection.
