Pocketship waterline
Waterline scribing time. I leveled the boat, and traced the <Dr. Evil voice> “Laser” line all around. The reference point (each side) was 16 1/2” from bottom of keel, as per instructions. The lines merged very neatly at the bow. At the transom however, one side ends 11” from skeg, the other 12 1/2” inches away. Even a small error is really magnified here as the surface is very oblique to plane of laser (at least that’s what I’m telling myself!). Now what? I don’t want the paint across bottom part of transom to be crooked. Should I fair skinnier out, the fat one in? Split the difference? that pencil tip shows where the laser line ended on the other side of boat
I think I’d split the difference and fudge it a bit. I wouldn’t paint a crooked line on. You could just take your boat out for a season and let the water and algae stain show you what to do.
worked out fine. Total Boat “Sea Green” and “Oyster White”. Also lots of dust.
That looks great! Bravo Zulu.
