POLYURATHANE OIL BASE PAINT
i IT POSSIBLE TO USE POLTURTHANE OIL BASE PAINT TO PAINT MY JIMMY BOAT? It will only be in the water a few times a month.
This is one of those "anything is possible" answers.  Purists will tell you that you need the $40/qt Interlux which is pretty good paint and holds up well.  I used Benjamin Moore oil based porch paint for the interior of my dory and it is also holding up well, at about a third the cost.  Never used it on the exterior but wouldn’t be against it if the boat wasnt going to sit in the water for extended period.  how about a test?  Paint up a piece of wood and float it in a bucket, see how long it lasts.
