Prepping Hull for Glass Cloth
Hi CLC Forum,
This is my first post on CLC's (or any!) forum. I'm building a Mill Creek 13. I started it when my daughter was born 11 years ago and am just getting around to finishing it now :)!
I have two questions about the procedure for prepping the hull for glass cloth.
1. The instructions say that I should first round off the chines and keel with a sander, and then fill any gaps with epoxy, and then finish sand them. My instinct would be to first fill the gaps and then sand them, so there is more material to sand off. Am I missing something?
2. I didn't see a step to round/fill the bow and stern. Should I do that also? Again I expect the finished look to be a nicely rounded shape but without the prep the glass cloth will cover a bumpy and rough surface.
Any guidance much appreciated!
Thanks,
Chris Hill
   Chris
I'm starting getting ready for my first build (a Sassafras 14) and when I get to the sheathing, I'm giving serious thought to priming the hull in CPES
I think that in the States it is sold by someone called Rot Doctor. It is a Clear Penetrating Epoxy Sealer and epoxy resin bonds with timber treated by it very well
Just something for you to consider
I tend to overthink things too :)
Tony
   1. Yes. When you sand the edge material off you'll expose new gaps even if you've filled the edges.
2. Yes, round all edges.
Have fun,
Laszlo,
Many thanks for your reply! I'm sure I'll post other questions as I overthink things.
Chris
   Generally speaking, you want to fill any gaps that you have in a strip build.  For the biggest gaps, use a razor knife to cut a sliver from the same color wood and glue in place with wood glue.  For the smaller gaps, fill with a paste made from epoxy and wood flour.  Unthickened epoxy won't fill the gaps.  Some try to use saw dust from the same wood but I have pretty good luck with wood flour.  For lighter colored wood, I mix in a bit of cell-o-fill with the wood flour.  Experiment to find the color that you want.  No need to mask, just fill the gap and wipe it flush with a putty knife.  Sand over once it is cured.  Don't worry too much about getting the color exact.  The overall beauty of the boat hides many small imperfections.
Once you have the entire boat sanded, wet down with a wet rag (water) to raise the wood grain, then once dry sand lightly with 220 grit.  The wet-out also closes the staple holes making them less visible.  Some like to coat with epoxy prior to glass but I am not convinced that it really helps.
agreed,
it's best/easier to do the football after the initial glassing of the hull.  its a lot easier to get a clean, easier to fair in edge of new glass over cured glass than the other way around.
Excellent advice from all above. I do carry a couple of steps a bit further though. After wetting the wood and finish sanding with 220 grit, vacuum the wood to expose all the tiny flaws you just filled with sawdust. I save my ROS dust in two containers, light dust and dark dust. I mix epoxy with a combination of the two to most match the boat then apply a coat of this "mayonaise" paste to the entire boat. This fills the small voids and seals the wood.
Wood will outgass and ruin your glass. There are two ways to prevent this. Either seal the wood before applying the glass or heat the shop up to 75-80 degrees and let everything heat soak for awhile then turn the heat down so everything is cooling off when you apply the glass. This way the wood is 'inhaling' instead of 'exhaling'.
Wood will soak up a lot of epoxy. It may look good as you squeegie off the excess epoxy and move on but after you leave, the wood will suck down epoxy at different rates depending on the tightness of the grain leaving white spots in the glass of epoxy starved areas. Pre-sealing the wood stops this.
As soon as the seal coat is dry, lightly sand with 220 again to remove any roughness and apply the first coat of cloth. As soon as this is dry enough to drag cloth across it withoug sticking apply your "football" glass.  For me this is an all day job but it ensures all cloth layers will bond together with no possible blush forming on the epoxy.
