I’m planning the same internal bungee hold down and finger divot. Question, I am about to glass the deck, should I divot before or after?
I divoted after.
Progress... just about ready to divot. What tool did you use for this? I have a dremel and was thinking that might be the best approach, other option I am considering is a simple drill. I have my test piece on the bench curing. Once the epoxy is done, will try a couple experiments.
I also used a Dremel, then finished it off with sandpaper wrapper around my index finger.
