I’m now ready to paint my Annapolis Wherry. I was ready to purchase Interlux Brightside, but reading the specs I saw where this product is for ‘above waterline’ . Is this still a good option for the outside of the hull or are there other options I should consider?
Provided that you will not be leaving your wherry in the water for days or weeks at a time, then the Brightsides paint will be fine for the entire hull.
"Bottom" paint is used when the boat is kept on a mooring or slip. It is formulated in a way to prevent bottom fouling, either as an ablative, or anti-fungal coating.
Please post pictures when you are done. We love to see new boats! - Ron
Ron, thanks for your explanation. I was hoping this was the case.
Since I will be 'in water' only during use I feel confident with using Brightside. Just never hurts to double check before proceeding.
Thanks again.
