Hi Ross,
Thanks for telling us more about the project..
Based on the information you shared, you are looking for a standard adult male kayak. Your weight, height and foot side is a typical adult male and that takes kayaks off the table that are designed for women and small men and teenagers. So we are looking for a real high performing sea kayak in a package of approximately 15 feet.
In the CLC/Nick Schade Catalog, that leaves you with the Petrel Play, the great auk 14 and, if you want to consider a hybrid, the shearwater sport.
Bjorn Thommasson, a popular designer in Europe has the Jack 14.
Ashes kayaks has the Allwater 15…which looks like a petrel paly with a little less rocker and a less curvy deck.
And Laughing Loon has the Dark Star…a baidarka……but you would be close to the top of its recommended paddler wight.
So there are plenty of kayaks for adults at 15 feet. However, you start to see two trends when the length gets shortened. First, they tend to widen them out to about 23 inches and second, the ends are more vertical (less overhang). The reason for this adjustment is you have less length to support the same size paddler so you manage the buoyancy by widening out the boat. And to keep the boat an efficient paddling machine, you try to have the longest waterline length possible so these shorter kayaks can actually keep up with the standard 17-18 foot sea kayak..
The challenge is you are probably not going to be able to get that night heron looks because the overhangs are dramatic…..and while beautiful, don’t leave you a lot of hull in the water to support an average adult male (170 lbs)…..unless you are prepared to have a boat that is relatively deep in the water….and that creates its own set of issues..
For whatever its worth, you see the exact same trends on commercially built, high quality, adult kayaks. When you want it in a short package, they widen it and the ends are more vertical.
Anyway, I think I can relate to how you feel. I have two night herons and a petrel. These boats are really beautiful….but they are long. As I mentioned, on my latest project, I want the whole thing under 15 feet….and I am going to play with a petrel play hull and a custom deck…..and see what I can do to make it lovely in its own right. Anyway, here are the pictures of the night herons, petrel, and the 15 footer I have just started:
i hope this was helpful.
