Anyone have any recommendations for a rack? The Malone and Thule sites fit guides do not have a solution they recommend. Amazon reviews slam the Malone's ability to clamp on the rails effectively. Anybody use a Thule model they like or any other recomendations. I just spent alot of time and effort on this CH18 and I don't want to take any chances while transporting it. It will be on the highway at speed for hours to get to a paddle destination.
Matt
Disclaimer I am not an employee of nor am I endorsing this site, rackattack.com. That being said, I got my racks there and they have their own fit guide which I found to work better than Thule’s, for instance. Just my 2 cents.
Thanks for the input. I emailed their tech support to get a refined solution. It looks like they will be able to hook me up.
I built my own J racks out of some 2x4 and spare 1/2" ply. 2,400 KM to PQ & back, the Duck and the Egret (17’ SOF) arrived safe and sound. Majority of the trip was on cruise @ 120KM/hr. Happy to email you details. david at dragonsong dot ca
Thanks for the link to rackattack, czdan. I've had a similar problem finding a rack to fit my GMC Envoy. They found five systems. After looking at the prices, though, I think I will stick with the $15 foam blocks I've been using for almost a decade now. -Wes
twofootartist, do you drive at highway speeds for hours with the foam blocks?
I try to keep my speed under 60 mph when carrying anything on the roof. At that rate it only takes a 15 knot headwind to create hurricane conditions. And since most rooftop carry failures involve the rack coming off the car, I use bow lines hooked to holes in the frame when I’m going to be on the highway. That said, I frequently travel long distances at highway speeds with no problems. I’ve also had no problems with empty foam pads on the roof rack at highway speeds, although I usually remove them when not in use. When the boats are properly strapped down, it should not matter whether they are sitting on cheap foam pads or expensive cradles. BTW, I carve the foam pads to fit the V-bottom on my Merganser and the flat bottom on my daughter’s Ganymede. -Wes
