Row Wing Fitting
G'day all,
I'm about to fit the Piantedosi Row Wing in my Wherry and there's mention of a cleat to be fitted under the seat.  Is this simply a glue block bewteen the bulkhead and the seat to add strength to the joint?  Will the epoxy stick to the varnish?  Do I simply bore holes in my seat and bolt the row wing in place from the underside through the seat?  Any suggestion of padding between the row wing centre channel and the seats of my wherry?
Thank you.
Scott
