Sanding Interlux Brightsides
Hi all,
Does anyone have thoughts on whether sanding large flat surfaces between applications of Brightsides coats with a low speed ROS and 400 grit is acceptable (as opposed to sanding the entire boat by hand)?
Thanks,
Mark
   I used my Festool ROS at 1 in several places with 320 grit. Just stay away from the edges and corners and you'll be fine with a very light touch.
