Hey all,
I'm getting closer to the finishing portion of my build on a CLC 17. I have a couple of questions on this I'm hoping folks can help out with:
1. I have more then a few epoxy drips on my hull (sigh). Should I take a furniture scraper to these and then move to 120 grit sandpaper on the hull, or should I skip the scraper and start at maybe an 80 grit instead? I'm a little worried about sanding through to the glass if I start with 80 grit (not necessarily where the drips are, but near them where my sanding disc will also hit while working on the drips)
2. I put an extra rub strip (just fiberglass) on my bow and stern, and that, combined with the overlap of the deck glass on the hull - how do I feather those into the hull? Should I expect to sand into the (top layer) glass a little bit to get a smooth edge, and have to recover with a bit more epoxy? Or should I expect a ridge where the top layer of fiberglass ends?
Max
