Scarf joints on the Skerry hull panels?
A question for the Skerry builders out there.
After meticulously laying out the hull panels against the sting line, I noticed that there was a small gap at the scarf joint on the #3 panel. The top of the joint butted nicely but the seam split away to about a 1/8 of an inch. I triple checked all the measurements to ensure the panels were symmetrical. The epoxy joint appears strong enough. (based on my total lack of experience) My question is should I fill the gap with epoxy now or just continue with the assembly and fillet the space latter during the glue process? Thanks Patrick
