Does anyone have tips on how to shape the stem line? I drew in the plywood and there is a very small crevice on the outside hull (no daylight shines through it) that I wonder if I should fill with thickened epoxy then sand or just sand down till it becomes a point prior to glassing. Project is a kaholo 14. Thanks
Your bow looks good. The small "crevice" is normal because on the Kaholo you do not bevel the plywood before stitching. No need to fill, just round it all over once the deck is on.
