Skerry Launch checklist
And here's a launch checklist I put together for my Skerry ("Raven") for a day sail, in the hopes of one day reaching the goal of 15 minutes, from time of reaching the boat ramp to time of shoving off.
0.    Remove Trailer Straps
1.    Install Auksiliary Oar Locks (in Blue Bungie Bag), Tie Secure Wires Underneath
2.    Install Rudder; Secure Tiller; Install Tiller Bolt; Secure Tiller into Slot; Raise Rudder Up, Tighten
3.    Install Daggerboard Filler Board into Seat Slot
4.    Lay Daggerboard & its Bungie Strap on Fwd Floor compartment
5.    Install carpet floor onto Aft cockpit floor; put two seat cushions there, towel
6.    Tie Yellow Bailer Bucket to Front Blue Tow Rope; put gray bucket nekst to it, w/Tow Rope inside it; put Sponge in Yellow Bailer Bucket
7.    Install FM/AM/Weather Radio
8.      Attach GPS & Time/compass/Temp console
9.    Put Life Jacket on Front Deck
10.      Put Equipment Bag on Aft Deck
11.      Put Orange compact Paddle onto floor of Aft cockpit
12.    Lay Black canoe Seat on top of Daggerboard Filler Board
13.    Put Sailing Hat in Rear Right Underdeck compartment w/Towel
14.    Put Boost in one Drink Holder, Put G-2 in the Other
15.    Put 10 Lb Weights into Under Mid-Seat compartments
16.    Lay Sail/Boom/Yard onto Port Side of Boat, the End with Blue Gaff String in Fore of Boat
17.     Undo the Sail Ties, place them into plastic baggy in Fore compartment; Remove Yellow Mast Strips
18.    Remove Mast Trailer cushions; Turn Mast with Vang cleat on Port Side
19.    Run Mainsail Halyard Thru Port side of Mast Hole, down into Front Deck Starboard Hole, into the Block, and Across to the Starboard Side cleat
20.    Attach Wind Vane to Top of Mast; use straight head screwdriver from toolboks
21.    Put Phillips, Scissors, and Velcro into Equipment Bag
22.     Put Black Raincoat Bag & Blue Bungy Bag in Fore cockpit underneath Middle seat
23.    Raise Main Mast, Install into Mast Step, Secure with Yellow Strips
24.    Pull on Main Halyard, Raise Mainsail to near Full Top, Secure Halyard to cleat
25.    Install Vang loosely, Secure Gaff Puller loosely, Install Mainsheet
26.    Lower Mainsail back down into Port Side of boat, Wrap Sail out of the way
27.    Install the Oars
28.    Disattach the Trailer Light bus
29.    Put Hip Boots on, Put Shoes back into Boat
30.    Attach Tow Rope to Bow Blue Rope, leave on Bow deck
31.    Drive Boat down to Boat Ramp, Dis-engage Bow Hook, Hold Tow Rope, Back car/boat into water
   Apologies for some spelling errors.  Some keys on my keyboard aren't working and so had to improvise.
You forgot talking with bystanders (always good for an extra 20 minutes):
1. Yes, it's a wooden boat
2. Yes, I built it myself
3. It was a kit
         or
    It was from plans
4. It is pretty, thanks
5. No, it's not for sale
6. It's for sale but you couldn't afford it
7. It weighs less than you do - really
8. It doesn't need a motor
9. Wow, your dog really likes my leg, doesn't he?
10. Chesapeake Light Craft
Have fun with your first launch and don't forget to post pictures,
   Ha!  You nailed it, Laszlo.   All true.
   Tell me about your daggerboard bungie strap. I need something like that.
   Sorry no pic but here's how best I can to describe it.  First, I wrapped and tied an old rubber bike tire tube around the daggerboard, just snug up against the handle top.  That helps to form a seal against the well opening.  I leave it on there permanently. Second, wrapped once or twice around the opening in the daggerboard handle is a foot long bungie cord.  Each hook of the bungie is then led aft so as to grip themselves onto the aft edge of the middle thwart/seat, outside of the small loop which hooks onto the mainsheet block.  The tension aft of the bungie cords on the daggerboard handle is sufficient I've found to keep the daggerboard pinned down and not slowly sliding upwards.   I hope that's helpful.  Let me know if it's not and I can email you a pic.
I don't have a picture handy either, but I've got an arrangement that's very simple and works quite well.  I've hooked a bungee cord from one of the limber holes under the middle thwart, up over the top of the dagger board, and back down to the other limber hole.  I can easily pull the bungee cord forward (or aft) to slide the dagger board in or our, and I can even pull the bungee cord clear of the dagger board and raise it part way up.  When I release the bungee cord the pressure of the bungee cord against the leading or trailing edge of the dagger board holds it in position. When I unship the dagger board, I leave the bungee cord in place and slip the oars under it to hold them in place on the ride home.  I'm not home right now, so I can't measure, but I'm thinking the bungee cord is about two feet long, relaxed.
hokker
