Space between the wood and the epoxy-woodfill "cork" for the holding cord (wooduck12)
Good morning,
I am at the end of the building of my wooduck 12, made 2 holes to pass a cord to hold the kayak through the epoxy cork (under the deck) and found as per the picture a 1mm space from the wood to the epoxy cork (I did this as per the manual). I used a thin metal string and it seems this space is at least (at its bottom) 20-30 mm. the hole ispositioned 30mm under the deck. I plan to wet with epoxy around (as in the manual) and also in this space and then put in this space some epoxy with wood fill (liquid enough so it falls down but not too much so it sticks to the 1mm space which I plan to fill-up).
Does it seem ok for you what I plan to make or do you have some comments/recomendations?
Have a good day, Eric
Maybe I must be more precise: this is during the process of End Pour :innocent:
Generally, when I do an end pour I don’t use the wood block. I drill the toggle holes first, tape the holes closed with some packing tape, stand the boat up and fill the ends with a mixture of epoxy and microballoons. I make the mix fairly thick but thin enough that it flows easily. This seals the edges of the wood where I’ve drilled the holes. Once it’s cured I redrill the holes slightly smaller and chamfer the edges.
Dear Dan,
thank you for your message. Sorry not being clear in my first message. I put mixture of epoxy and woodflour (charged epoxy) to make this “cork”.
I like your process and will make this on the second wd12 I will build (my wife’s).
The situation I have is that there is a small circular gap (1mm) all around the hole I drilled (12mm diameter for the cord) and the panel (wood and its 4 layers of epoxy and the fiber glass) and it is up to 30 mm deep. My understanding is that either this charged epoxy did not stick on this part or that during the curing process its volume reduced only on this side and this is the gap I discribed and is shown on the picture.
My intention is to put first a small quantity (wetting) in the whole surface of the gap with epoxy. then put some charge epoxy to cover the internal parts of this gap.
My question is: is my intention convenient ? is it adjusted for this size of gap or should I consider a “stronger action” ?
Have a good day,
Eric
PS: I am sorry if my descriptions are not all that clear; this is my first boatbuilding and English is not may native language and specially on boat terms.
i think your approach, if i understand it, is fine.
i have had that happen. you drill out the hole and now you see some gaps.
so as you said, one wipe of unthickened epoxy.
then i would follow with very thickened epoxy applied with a popsicle stick to push it into the gap and then use the popsicle stick (that has to be smaller then diameter of the hole), to clean it up (like a small spreader).
resand the hole once you are done and then you are all done :slight_smile:
Good morning,
thank you for your comments.
Well, I went for it. It did not go precisely as I planned but the fact that I prepared it and with your comments I believe I acted correctly.
I did the basic actions:
  • wetting with epoxy and it “went way” so refilled again (falling in the gap which was more than 3mm deep) but I believe covered at least 10mm all around the gap
  • filled-up with thickend epoxy (soft-mooving mayo) and it also went away (falling deep in the gap) but slower and not totally (it seemed some epoxy got stuck on the internal top parts of the hull).
  • filled-up with even thicker epoxy (between liquid honey and very soft peanut butter) to be honest a few mm only.
At the end I believe about 10-20 mm have been receiving some epoxy with various viscosities so the 1mm gap is now filled and “blocked”.
Basically I made a 3-5mm ring at least of epoxy so mecanically and in terms of waterproof (in my view of beginner) it should be ok.
Hopefully : more fear than harm
Again thank you for your comments and next time I will make a drill-fill-redrill technique which sound smart.
