Christine,
I built a carbon fiber mast and sprit for my brand-x sailing dinghy. I used "sock" technology. That is, tubes of material pulled over the mandrel, rather than sheets rolled around it. I used 2 different styles of building for the mast and the sprit.
The mast has a 2-inch diameter core made of pipe insulation foam. The ends and the area where the mast passes through the partner are reinforced with glass tape. The layup schedule for the mast is biaxial glass, linear carbon fiber and biaxial glass again. The pipe insulation (a closed cell foam) stayed inside when the mast was done. The top of the mast is plugged with glass and wood putty and has a stainless steel eyebolt (the same as the Skerry, in fact, I got it at CLC)to anchor the lashings. The mast came in at 2 lbs without paint and without fittings.
The sprit is 1 1/4 inches in diameter. It was mainly an experimental piece, testing several different ideas and a new supplier of materials. It ended up way overbuilt and about the same weight as wood. Same general idea as the mast - linear CF sandwiched between biaxial glass. It's hollow with wooden plugs at each end. The nose is a dowel shaped to fit the peak loop in my sail, while at the knee the wood is entirely within the mast and acts to reinforce the mast for a hole for the snotter
For fittings I put a wooden collar on the mast with dowels that act like fixed belaying pins (they're recycled from CLC disposable foam brush handles).That way I didn't have to drill any holes in the mast.
The epoxy should be a high modulus one, like Silvertip or its equivalent. The main trouble I had was getting the work off the mandrel. Pieces of pipe, conduit, etc. have tiny irregularities in shape that are harmless in short lengths, but when extended to 10 feet or more make it impossible to get the work off the mandrel without cutting something. A foam core works much better (either pipe insulation or 2-part structural closed cell).
Cores and mandrels also like to flex. The easiset way I've found to make a straight mast is to hang the core vertically and work with gravity, instead of against it. That does need a tall shop and/or short masts, though. I'm planning a 21-foot mast later this year. That'll be hung from a tree once the great outdoors warms up again.
The early stages of my mast construction are at Krakenbait Gets a Carbon Fiber Mast. Now that the boat is finally finished, I need to go back and finish updating the mast pages.
Good luck with yours, they're a lot of fun.
