As both a sea kayaker and long time windsurfer I have years of experience loading both kayaks and windsurf boards and gear in and out of my vehicles. Recently, becoming frustrated with having to carry all my windsurfing sails and masts inside my Volvo XC, leaving no room for anyone else to sit, I began to think about better ways to securely carry them on my roof racks.
Looking at the exisiting roof rack mounted Yakima and Tule type sport cargo boxes, none were long enough to accomodate my larger windsurfing sails and masts. So I decided to just build a sail/mast carrier.
Having built both a Chesapeake 17 and 17Light kayaks from CLC kits a couple years ago, plus having a lot of composite epoxy building experience from working on hang gliders and ultralight sailplanes, I decided to use the basic stitch and glue technique to fashion a custom roof top carrier.
Below is the link to my photo building journal. The carrier is 10'2" overall and has 9'6" of usuable space inside. At the rear base it is 26" wide, 15" tall, and 18" wide at the top. From the rear it tapers forward. In this way the longest sails and masts fit all the way forward while shorter masts and sails fill up the larger section.
The final weight is 40 pounds as there is quite a bit of surface area plus the bottom panel is glassed both sides. If I built again I would use 3mm plywood for the sides and top, vice 4mm. 3mm plywood here in Belgium is hard to find and very expensive. I also would use 4 ounce glass on top and sides vice the 6 ounce I used for this prototype.
I have used it a couple times now and it works very well. The great thing about it is that you can build one to any dimensions you might want.
Here is the link to my photo building journal.
"http://www.flickr.com/photos/12085832@N08/sets/72157603831714114"
Good paddling and windsurfing,
Chuck R
Ronquieres, Belgium
