Strongback Length?
I'm a first-time builder, getting ready to build my Sassafras 12 (I have the kit).
I decided to go all-in and build a strongback before starting on the boat.
I have all my plywood cut to make a 14' strongback, when I realized there might be drawbacks to having a strongback that's longer than my boat.
Does it make a difference?
Would I be better off making a 12' strongback?
Hi Brian,
it depends on what you mean by a strong-back.
  1. in kayak construction, the typical strong back fits inside the hull and the forms have a whole in the middle for the strongback...so the strong back has to be shorter than hull - often substantially.
  2. the other apporach is a table or strong back which supports a series of vertical posts to which the forms are fit (so they all sit above the table/strong-back).  in this case the strong back can be longer than the boat.
the strong-backs so by CLC are desgined (with respect to their dimensions to fit inside a hull and have to be cut to a precise length.
if you want to build a table (2 above), you are not limited to these dimensiors.
hope that helps.
   But just to get more speciifically to your question....no issue having the strongback longer if you are building situation 2 above.   it means you can now re-use or build a longer boat as your secod project without having to build a new strongback - warning, this hobby can become addictive.
