I purchased a Tenderly kit recently and thought I'd post the build so others can follow along and critique and maybe I can learn something.
I've helped build two boats before at the Edensaw 3 Day Boatbuilding challenge at the Port Townsend Wooden Boat Festival, but I was mostly unskilled labor and could have someone else do all the challenge bits. In 2018 we built a Tubby Tug, and in 2019 we built a Jimmy Skiff 2.
I bought a Tenderly kit because I thought it looked good, it would theoretically fit on top of my car, and most importantly it could definitely be removed out of my basement upon completion (the PMD is right at the theoretical limit). I was also interested to see how a boat goes together when cut by a mathematically perfect CNC machine, as opposed to when cut by imperfect humans.
Lugging the boxes into the basement single handedly was an adventure, as was opening them and removing an incredible amount of packing tape. That said, CLC clearly has this down a science and everything arrived without damage.
Soooo much packing tape
I tried all the listed ways of removing the machine tabs, and what worked best for me was a rasp. I kept tearing the middle layer of the plywood with a chisel or with a plane. Using the aggressive side of the rasp to remove most of hte material and the less aggresive side to finish it off I could get a nice fair surface with no tears.
See tear out from using a plane.
Nice and smooth using a rasp.
Cleaning up the puzzle joints with a little sandpaper was a breeze, and they fit together perfectly. I think I put a little too much cell-o-fill into the mix (resembled cold gravy), but it still spread well enough and I assume it will work out fine. My biggest mistake was buying sterile tongue depressors so they are all individually packed...
Leaving the hull plank puzzle joints to cure overnight
Very annoying to unwrap every popsicle stick
