Hi everyone, I am building a Jimmy Skiff from the kit and had a question. I have epoxied the sheer clamps together using Cab O Sil thickened epoxy, and I'm ready to attach them to the hull, but wasnt sure if I was supposed to use un-thickened or thickened? In the manual it only says 'glue them to the hull', leaving me unsure.
As a related question, should I assume I am supposed to use Cab O Sil thickened epoxy when it only says only 'glue' in the manual? It's obvious what to use when it says fillet, but other times it doesn't specify.
Thank you everyone!
