Thigh Braces.
I am redoing my failed attempt to make the perfect thigh braces.  Does anyone have suggestions? pics?
My only suggestion is to get foam, sit in the boat and figure out where you want the braces and then start carving.  Keep trying the fit.  you can use double sided tape to trial fit and actually paddle with them until you get them right, then glue them in. or you can use sticky back velcro as a temporary hold.  You can then pop them out, carve a bit and then try them out again.
Try this link also:  http://kayakfit.tripod.com/instructions.htm And then click on knee braces.
Ed
