Hi, I have never ordered an aluminum trailer by mail before, so have no frame of reference. My Trailex SUT 1000 for the Teardrop just arrived today and I have a a few questions. Is it normal to have many aluminum pieces scratched and dented? Additionally, about a dozen T-slot bolts and nuts were loose in the box and I fear some may have fallen out as the inside box had a sizeable tear in it. I am waiting on the 4th box to arrive which I hope has some kind of instruction manual/parts list so I can determine if this is the case. The manual will also be helpful because one piece (I believe it’s a crossmember; it’s labeled in ink “F” if anyone has a recollection) has ends that look to be mirror opposites of each other, aside from one corner on one end piece having a very noticeable bend in it. It’s hard to tell if this is intentional or another instance where there could be an issue. I understand a utility trailer isn’t a coffee table (and much of this will likely be hidden) but I wasn’t expecting dented, scratched, and possibly bent parts either. Thanks!
Not normal.
While not a coffee table, some of those are serious dings/dents/bends and i would contact vendor/shipper and report it damaged and appropriate relief.
Aluminum trailers generally should be quite clean compared to their steal based counterparts.
Aluminum, while strong, can be brittle if deformed like that flang area that is bent.
That said, above is in the context of purchasing a new item. Some of the damage appears to look like prior use and assembly, disassembly induced damage.
Howard
Hi Howard, I really appreciate your reply and I, too, thought it looked like it might’ve been assembled prior (especially around the bolt holes in the photo with the Sharpie “F”). Could it be Trailex assembles their products to test fit, then disassembles them before shipping? In any event, I paid for a new trailer and worry this might have been a return. I emailed CLC earlier tonight and hope to chat with them or Trailex Monday to see what’s what. Again, appreciate your take on this!
Patrick
i think you are right…they somehow shipped you a return. i bought a new trailex before and it was clean as a whistle and no evidence of pre-assemble/disassembly.
I’ve bought 2 Trailex trailers as new kits form CLC/Trailex and 2 assembled but used from other boat owners. Neither of the new ones looked like yours in the box. They were absolutely clean, shiny and well-packed. I’ve never seen any evidence that the trailers are pre-assembled and dis-assembled as part of a checkout. That bent flange, especially, is not something that a new trailer purchaser should be receiving. I never saw anything like that, even on the used trailers.
You need to talk to Trailex about a replacement or a really, really good discount plus replacement of any missing parts. (Did you report the tear to the shipper?) This is an exceptional event, not something I’ve ever seen from Trailex before, so they’ll probably treat you right. They care about their reputation.
No need to wait for the 4th box. The assembly manual is available electronically from CLC on their SUT-1000-CLC page. Here’s a direct link to the PDF file.
Good luck,
Thanks Laszlo, appreciate the additional context you provided and the link to the online manual. It all seemed pretty strange and still wonder how many loose bolts and nuts were lost through the hole in the box (I found one in my yard). The tear and hole in the box is on the very far end but damage to the pieces is throughout the entire length so I don’t imagine the puncture caused much, if any, of it. I have apparently 60 days to file a claim with the shipper so will keep that as an option should anything get complicated with Trailex (which I doubt).
The more I examine the parts, the more it seems like it is a return. Funny enough I think it wasn’t fully disassembled as there are several mis-aligned L brackets bolted on in places I would’ve thought I’d be taking care of. Additionally, the blue Sharpie is only on a few pieces so now thinking it was the original owner’s way of keeping track of pieces and not necessarily a Trailex thing.
Not to pile on but there are a LOT of aluminum shavings in the box with the axle and they’re stuck to the hub where it’s a bit sticky with grease. In all honesty, I’m likely going to request a whole new trailer be sent but short of that, is it safe to assume this is a part that should definitely be replaced?
Whole things seems like an honest mistake and hard to get too upset about considering I’m about to start the teardrop project I’ve contemplated for years. As of now, it’s a kinda funny tale I can tell!
Thanks again!
Keep us updated.
If you bought new, then what you got was a mistake and i would not accept a piece by piece replacement based on what we have seen and additional bits you described.
It will be eaiser , i suspect l, upon sorting it out that shipping you a known new one is going to be the easiest way to quickly and reliably resolve the problem.
I agree it was likely a return - evidence the washer impressions in the F marked piece. This was assembled tightly at one point. The deep/through scratches and other blemishes also warrant a replacement for your “new” rig.
Thanks, Howard. CLC requested some photographs early today and I hope to have an idea of a resolution soon.
Thanks, Dusty. I have no frame of reference for what abuse an aluminum trailer goes through in manufacture so it’s good to know this isn’t normal!
I’m about to pull the trigger on a new trailex trailer. Hopefully it goes better.
Jon, I definitely hope you have a better experience than I. Just got off the phone with CLC and after their conversation with Trailex earlier today, it seems like a straight return/swap is nowhere in the cards. Trailex claims they’d never send out a trailer in this condition and that they’d not assemble/disassemble a trailer before shipping. It sounded like even the question ruffled some feathers in the shipping dept at Trailex.
CLC was super understanding that I’m a bit taken aback at their response. I had held off opening the last box (which didn’t arrive until yesterday) until now thinking we’d just swap this for another, but was advised to go ahead and open it at this point. Pieces in this box are abraded everywhere, too. This box is also punctured and has loose nuts and bolts hither and yon. I was hoping this box contained a parts list but it doesn’t. There’s a manual but I have no way of easily knowing what might’ve been lost between Ohio and Colorado. Nowhere in my conversation with CLC was it implied that the damage to the boxes would have contributed to the type/extent of damage.
It was advised by CLC to do my best to take inventory and send along additional photographs of any parts I’d like to have replaced a la carte-style. I was told a discount would be offered but we didn’t talk specifics yet.
Photos below are of the last pieces to arrive and in addition to what’s above:
This is appalling. First though, keep in mind that CLC never touches the Trailex trailers. They forward the order to Trailex who ships it directly to customers. This is 100% on Trailex.
That said, you have photographs documenting damaged shipping boxes and product. Presumably you paid via credit card. I’d get in touch with the shipper to file a claim for shipping damage and get in touch with the credit card company to dispute the charge based on Trailex not delivering what you paid for.
That might be enough to get them moving. If not, you might need to resort to small claims court and/or no-star reviews.
I still find it amazing that Trailex isn’t replacing the trailer. All my dealings with them in the past have been very professional and they really seemed to be intent on keeping the customers happy. Maybe you need to get hold of someone’s supervisor.
This is more than just shipping damage. Someone assembled it (poorly), disassembled it, tossed it back in the boxes, and somehow you ended up with it. If it was me I would settle for nothing less than a brand new trailer.
I hear you, Laszlo. My concerns are 100% directed at Trailex. CLC has been great and very communicative and understanding of my bewilderment. The conversation is apparently ongoing with Trailex and I hope to get an update today from CLC. Depending on how that goes I’ll weigh my options.
I built my first CLC boat (Chesapeake 17LT) 17 years ago and the teardrop will be my 5th build and fall-sale skerry, my 6th. I have nothing but great things to say about CLC over all this time and harbor no ill-will toward them. Hoping this gets sorted!
Appreciate it, Dan! It’s a weird position to be in as I’ve never purchased an aluminum trailer so really don’t know what would be considered normal. In terms of the cosmetic damage I found myself wondering if that’s just the way these things go? I looked to see if there’s a Trailex retailer in the Denver area to see something in-person to compare what they received vs what I received but there’s nothing close. Oh well.
One thing that occurred to me, I’ve assembled a couple of Malone trailers and they all came with paperwork that included something similar to a vehicle ID number. If you received paperwork that has one Trailex should be able to trace where it was.
Good thought, Dan. Here’s what CLC says about the paperwork:
Trailer Licensing and Registration: Most states require a trailers to be licensed; please refer to you local motor vehicle administration for specific details. Each trailer is issued a Certificate of Origin by Trailex and Bill of Sale by Chesapeake Light Craft. All drop-shipped trailers will arrive before the registration paperwork. The Certificate of Origin must be sent to CLC to be signed over to the first owner of the trailer. Please allow 7-10 days for paperwork to arrive.
So the paperwork should be at Patrick’s late next week. In the meantime, the tracing process can get started right away. For Trailex trailers, the VIN is on the info/legal compliance sticker that’s on the top front of the tongue, up by the ball coupler. That sticker has the tire inflation pressures, the regulatory compliance statement and effective date of compliance, safety information and the VIN. If the previous owner had possession long enough for a certificate of origin to be generated, Trailex out to be able to find it based on the VIN. It may also be possible to find the shipping info based on the VIN. This may be the most productive suggestion so far. Dan wins.
Patrick, you tuned in?
Dan and Laszlo, thanks! The cert of origin/VIN is a fun thread to pull on especially since I got word this afternoon that we’re at a stalemate. CLC spoke to Trailex earlier today and provided more photo evidence of what’s going on and according to CLC, Trailex admitted (again, I think??) that the damage is not typical but they feel most is superficial so not to worry (second verse same as the first). At this point for me it’s more about paying full price for something with wear and tear, and less a question about whether or not it’ll catastrophically fail (though it’s agreed there are several parts with more than superficial damage).
CLC assured me Trailex seemed more open now to swapping out any pieces I want. But I said at this point, it’d be darn near everything. CLC did refund me the shipping charge associated with the trailer which is nice.
The irony (and lesson learned) is that I wasn’t even planning on opening the boxes and assembling the trailer until it was was time to mount the teardrop. If not for the damaged box, I might not have known this was even a thing for months (I work slowwww!).
Aa Laszlo mentioned before. If i paid with a credit card for a new item, i would dispute the charge and use that avenue as well.
H
