Update on the Ducks
After five or six trips paddling with both the WD10/12 I built, I moved up the addition of epoxy/ graphite to the bottom of the WD10.(my WD12 was originally finished that way).
It is clearly a better solution for a boat that is going to be used. While the Varnished bottom continued to accumulate good size scratches, the Epoxy/ Graphite just gets rub mark.
So rather than wait till the winter, I did it this past week.
Also added some nylon washers under the hold downs for the flush hatch. I found they were constantly sticky tightly to the deck and hard to turn. The washers seem to help. This winter I will add a "laszlo style" recess to the hatch to make it easier to take off. I find the hatch sticks pretty tighly to the foam seal.
Overall they are ablast, and happy to own them!
David
