The manual for the WD-12 is not clear about where the ends of the adjustable nylon straps for the back support should be screwed in to the underside of the deck/coaming assembly. Can anyone say how far forward of the cockpit bulkhead they should go?
Thanks.
Jim
I eyeballed mine. I made sure that I had enough webbing. too far back and they tend to pull sideways that increases the pressure on the screws. The further forward the more straight back the pull, I will measure it when I get home and post.
14" forward of the Bulkhead.
Thanks, that's just the info I was looking for.
Jim
Are the clips for the tension bunge on the back side attached to the underside of the coaming or to the bulkhead?
Tom
I attached mine to the underside of teh coaming.
Ralph
