Finishing up my WD12 and taped off the water line with green painters tape and applied last coat of epoxy/graphite .The suface for the tape was smooth and the tape was rubbed down but the black wicked under anyway, not much but I will forever see it. Should I have used the blue tape instead? Any suggestions would be appreciated.Thanks
i don't rely on blue tape anymore. "frog tape" is the best product i've used for crisp lines. it's green and the directions say to moisten it prior to painting. it "shrink wraps" itself to the surface yet is easily removed. it's available at the big box stores, a little pricey but isn't everything that works...
p.s. worked great on my wd10 fiberglass deck over-wrap too
Thanks…that sounds promising…I will raise up the water line 1/4" and try the "frog"…the wife says i should work out all these little problems before I build hers…I didn’t know I was building her one ?!
