I'm ready to glue the decks to the shear clamps of my CH-16 LT. Let's say I mix up a batch of epoxy using MAS slow hardener and the temperature in the garage is around 50 degrees F. As the day warms up, the temperature in the garage increases to about 60 degrees F, but at night the temperature drops back down into the mid 40s F. Will the epoxy eventually cure without using a heat source?
Thank you,
Mark
